Thunderbird BLOCKING Quicken From Sending Email Invoices
Thunderbird Ver 60.5.2 Running on Win 7 Pro
Problem = This morning I was trying to send an EMAIL from QUICKEN.
I created an invoice in Quicken and then hit "send email"
As soon as Quicken tried to send the EMAIL I got a message from Thunderbird that said something along the lines of:
"An external APP is trying to access Thunderbird"
"Notify each time this happens"
I click "no"
The Warning box closed BUT the email did NOT send.
Now every time I try and send a NEW email from QUICKEN and use Thunderbird as the email client, nothing happens.
No window opens, no message comes us, nothing....
What setting in Thunderbird to I need to access / change in order for it to ALLOW outside apps to access Thunderbird and allow them to send email VIA the Thunderbird client?
Many thanks!!
所有回复 (3)
This is the EXACT message I got:
Another application is attempting to send mail using your user profile. Are you sure you want to send mail?
I found a way to turn back ON the "warning"
BUT - Now what happens is that Thunderbird just sends the email WITHOUT giving me the option to edit the title / content / signature / ect
It used to open a NEW window with the EMAIL I was about to send and let me edit it if needed BEFORE sending it out
How do I fix this?
Thx
This is a bug in the newest release. There are dozens of post about this over the last 2 days. You can look through these posts for solutions but the common fix seems to be go back to an older version until they fix the bug.
